blue_sky
New Member
My boat has an inner forestay (for use by a storm jib - so I don't want to remove it entirely) that seriously gets in the way when tacking, so it's unclipped and taken to the toe-rail. The problem with that is that the toe-rail is considerably closer than the pad-eye on the foredeck meaning there is a lot of slack, and this results in and interesting use of string, and a cat's cradle arrangement to avoid kinking the stay be still keeping it out of the way - ugly is an understatement, and it certainly isn't seaman-like.
I've had the yard quote for replacement including a lever (currently it's clevis pinned and split-pinned - which will be fun in a blow). They suggest a shorter stay that would attach to a new pad-eye to be installed at the mast, and a strop between the deck pad-eye and the lever for when it's to be used. For all this I've been quoted a lot more than I can afford.
Can anyone suggest a cheap(ish) and seaman-like alternative?
Justin C, by the sea.
Trintella 1a, 'Kooshty'
