Stopping PVA beading up
bigwow
26 Feb 2006
How you stop the PVA beading up when sprayed onto a fibreglass mould after polishing?
/forums/images/graemlins/confused.gif
I should point out I have been starting with a mist coat but this has made no difference
The PVA is supposed to be water based, it washes off with water and the wax is silicone free. Trouble is it's a complicated moulding and if I just use wax I feel it will be hard to release. I am using the PVA so I can put a hose in to wash it out, so making release easier.
It sounds as if you are trying to apply the release agent toooo thick
use a piece of fine textured sponge, immerse in PVA fluid squeeze nearly dry then wipe in one direction only dont go over any areas already wiped
