Modulation
The tank used to have a fairly useless gauge at the top and the rigid plastic screwed down cover plate leaked heavily if the tank was full and the boat heeled. The opening is about 60mm dia and the cover plate 90 mm dia.
Surmising that the problem was that the 6 screws were not capable of being tightened enough, I replaced them with bolts so that I could bolt the plate on firmly using silicon as a gasketing material and to seal the bolt heads. I chucked away the gauge. Fortunately, the large screwed access panel to the tank is just beside the opening.
All ok for about 4 weeks but then the leaks restarted. And now there as bad as ever. Grrrrr.!
Any ideas for a permanent solution?
