Kelpie
Our boat has a bronze centreboard housed in a lead stub keel. Unless you are hard on the wind in fairly flat water, or alternatively you have wound the keel very tightly up, it is liable to clonk from side to side. Most of the time this hasn't been a bit problem, but certain sea states make it quite irritating. I also assume that this causes some wear on the pivot pin.
I'm thinking of addressing this problem by adding some sort of packing. There is a small gap, say 5-10mm from memory, at either side of the keel, so any packing would have to fit within that. Considering using a hard plastic type material, e.g. PTFE sheet. Possibly two thin layers, one bonded to the centreboard, the other on the inside face of the slot.
Just wondering if anybody has done something similar, and lessons learned, etc?
