Stop solenoid conversion to manual.
rotrax
17 Dec 2010
South Oxon and Littlehampton.
The elderly but up to now very reliable Westerbeke 8KW Generator on our boat started to randomly stop. It would instantly restart and run for some time before stopping again. Although I am very well versed in diagnostic techniques, the fault never manifested itself when I got the spanners and multimeter out. I did have an inkling of what the fault would be, and was eventually proved correct.
Being wise beyond my years and not prepared to spend hours looking for a non existent fault in confined quarters, I soldiered on. Eventually, my mental diagnosis was found to be correct. It stopped, would not keep running unless the heater plug switch was operated. Bingo!!!
The stop solenoid has two windings. When the unit is turned off, the magnetism is removed and the plunger spring pushes the rod into the pumps fuel stop mechanism. Turn the unit on ready to start, a current is sent along one of the windings, a fairly small current. This is not enough to pull the plunger out and allow fuel to flow. Operate the heater plugs and the solenoid is fed, through a heavier winding with enough current to open the fuel supply, allowing the unit to start. Once running, when the heater plug switch is released, the heavy winding is not fed, but once the plunger is pulled back by the generated magnetism, the light windings magnetism is enough to hold it open, keeping it running normally.
It was this lighter winding that had failed. I removed the solenoid and took it home. With it removed, the unit ran perfectly. By poking my finger into the solenoid hole and pushing the stop lever inside, it stopped.
At home I set it up in the lathe, turned the end off and removed the guts. It had that nasty 'burnt winding' smell. I replaced the electic guts with a manual cable operated rod, using the origonal internal spring and a bit of 6mm bore alloy tube, a bit of 6mm steel rod, a bit of alloy plate and strip and a motorbike brass spoke nipple modified to be a solderless nipple. A simple angle bracket screwed to the now hollow solenoid body became the fixed cable support.
The only cost has been a 17 quid 3 metre stop control cable from that wonderful old fashioned 'we've got everything' car spares shop in Littlehampton called "Going Spare".
The stop cable will take the place of the stop switch on the panel, keeping it looking good and keeping it simple. I could have got a new solenoid but it is an obsolete model and the only source was the US. Too much hassle and I might have ended up with the wrong part. Anyway, as my old mentor, race sponsor and all round top engineer Bill was fond of telling me "An Engineer is a bloke who can make for a tanner wot anyone can buy for a quid!"
Cant wait to get it installed and tested ! :) (y)
William_H
28 Jul 2003
West Australia
I would be a little reluctant to go manual stop on the generator. I presume there are multiple safe guards that stop the engine automatically like over temperature loss of oil pressure or perhaps an electrical fault. This safety factor would be lost on a device where you want to be able turn on and not hear it or think about it. ol'will
rotrax
17 Dec 2010
Thats what I would want, ol'will, but they cost 20K installed. I bought this one from ebay, in perfect running order, but from a commercial boat and without a sound box. After preparing it, buying the associated bits for installation, making specialised stuff for the block and tackle and a simple wooden 'trackway' for the special trolley needed to get it from outside the boat to its dedicated Generator Garage and having a custom made sound blanket built it cost me 2K installed. This might be the kiss of death, but it has only suffered recently from the fault in the OP and it has been in use six years.
After extensive testing and bringing up to my standards in my home workshop, making some modifications to remove the safety cutout features as my fairly large experience of marine gensets means I am aware that most faults are within the safety cut out features. If there is oil in the sump, water coming out of the exhaust, the A/C output is within the voltage and required cycles all is good as far as I am concerned.
It is only run when we are aboard, used mostly for electric cooking and heating the calorifier for showers, sometimes to use mains power tools. I am always ready to stop it if a problem manifests itself. It required going to the panel and turning a key to stop it, now you will pull a button on the end of a stiff wire cable. Little difference.
I understand where you are coming from, but after 60 years of fixing mechanical/electrical things, often for a living, I am firmly of the opinion that KISS is the way to go.
Keep It Simple Stupid............................................ :) (y)
