stirling alternator booster wiring help
steve28
19 May 2003
Cornwall
www.falmouthgypsy.com
Its the older yellow box type, stirling being their usual helpful selfs said they would email me the manual but havnt.
Does anyone have a fitting instructions or know which wires go where ?
It does not have the same wiring as the ones on the website.
Wires from the box are red,black,green,brown and yellow.
thanks in advance
steve
On the later model I have, the instructions show the wires as:
RED: Sense Wire goes to Common terminal on Battery switch (but can go to other places)
BLACK: there are two cables (and must stay as two) goes to B- or B Neg or the alternator case
GREEN - THIS HAS CHANGED TO WHITE on new set up and is the Field Wire that needs to be fitted to the alternator (to the Brushes by the look of it - I got an Auto electrician to sort this)
BROWN to D+ on back of alternator
YELLOW connected to ignition switch or any 12/24v supply that is 'live' when the engine is running.
I have a copy of the instructions in full - near Helston and if you want to see one wired up the boat is in Falmouth.
I can fax a copy too.
PM me for further info?
Be careful fitting the green (now white) to teh brushes - you need to know which brush - Down load the instructions from the Sterling Power web site.
"Artificial intelligence is no match for natural stupidity"
