Still finding out new things.....
asteven221
6 Jul 2003
with my "new" Sealine F44.
If anyone has the same model (or a 420) I would appreciate it if you could help me with the following:-
On the electrical switch panel opposite the galley, what is the purpose of the keyswitch and the two adjacent buttons Red/Green. They are marked as "DC Isolator". The previous owner didn't know!
On the same panel beside the battery charge on/off switch it says "do not run the engines with the DC battery charger on or it will be damaged" - or similar. Hmmm that sounds odd. I would have thought that there would protection diodes in the charger to deal with what is an inevitable situation where you forget to switch off before starting the engines. I have done it already and nothing seemed to blow up!
The boat has electic toilets. We have them set to discharge to the sea although there is a holding tank fitted. Does the clean flushing water, come from the sea or from the fresh water tank? I am reluctant to do a taste test!
Thanks for your help folks.
Remote battery isolator, the 390/410/420/450 were fitted with a ETA remote battery isolator switches for both battery banks. Turn on key, press on or off as required, it's a white box around 150mm x 100mm x 100mm.
We used to supply a mains battery charger that interfaced to the starter motor, later boats had a Serling that did not. The note was to cover them, if you damaged the charger by starting the engine.
Brian
Thanks for your advice Halcyon. I don't think it's a Sterling charger, but the fact it could be wired to the starter motor explains why there is a warning label.
