lesweeks
Following advice gained from you knowledgeable forum members, I've decided to cover the deck of my 1912 yawl with ply and a layer of glass. Sensible move most would say. However I now have another problem. The deck was covered with, now defunct, Trackmark plastic and was glued down. Although the covering itself comes away easily enough it leaves behind a sticky glue residue. Does anyone have a smart way to remove this as I am assuming that the wood needs to be clean for the new adhesive to work properly.
I've tried a small area with cellulose thinners and this softens the glue and makes it easy to scrape off (very messy though), but this would require a lot of thinners and I'll be a high as a kite!
