sticky ball valve
ortogo
24 Mar 2012
the ball valve on the toilet outlet on my boat is quite stiff is it safe to lubricate the "ball" with some type of lubricant to see if I can free it up a bit?
It could be about to die
I had problem with mine & it had dezincification & collapsed when i tried to disconnect the hose.
It seems heads outlet suffers the most from this
On another valve i stripped it & cleaned it with acid . This seemed to get it working ok
It is probably a buildup of crud around the ball through lack of use. Difficult to shift, although I have just freed two by squirting WD 40 up from the outside and working the lever back and forward to break up the stickiness.
Dezincification is a worry. Why would anyone use brass for a seacock?
