hebdena
Active Member
Hi all,
For a while I have had a slight leak from around my sterntube on my Rival 31.
Now that I am out of the water for the winter I am tackling this problem. I have removed all the hardware and the sterntube itself. The outer bearing cap was not sealed hence the leak and the inner cap was loose as the screws securing it to the hull were loose and had crumbled at the touch of a screwdriver, hence the leak.
There is a void space where the sterntube passes through and this appears to have been filled with some sort of foam. This had turned to a very soggy mush which I have been able to remove the bulk of with my VAX vacuum cleaner.
My question is : should I replace the foam and what with? or should I leave it as is?
I am going to leave the void space to dry out for a few months before I do anything.
Another question: I need to replace the screws that secure the inner bearing cap. The original were brass or bronze which had deteriorated very badly over time. Should I replace them with stainless steel screws? (brass bearing cap) or should I stick to the original material and what would that have been, bronze of brass?
Last question: where can I get the screws from?
Thanks in anticipation...............Andrew
