tonybarley
Good morning,
I have a problem about which I hope you may be able to advise me.
In October last year, I had a Bennett Trim Tab system installed on my 10 metre, Sealine power cruiser. At the same time, I had the twin prop sterndrives totally refurbished, anodes replaced and antifouled.
A few weeks ago, I experienced a failure in one of the sterngear legs and, when the boat was lifted out of the water, it appears that both the sterngear legs have corroded due to electrolytic reaction in the marina (saltwater environment).
I am told that, after a total rebuild of the sterndrives, the boat will need to be placed back into the marina in order to establish what is causing the corrosive/electrostatic effect.
I notice over the last few days that the trim tab 'flaps' and Bennett cylinders are unaffected. There is no electricity supply to the mooring; I therefore rule out any 'mains' effect from the marina.
I also notice the trim tabs are able to be operated without switching on the ignition; I am surprised the trim tab system was wired directly into the batteries and not into the ignition!
The question is, would it be possible, due to negligent installation, that there is an electrical potential has been created on the flaps and this has caused the damage to the sterndrives
Any help or advice would be greatly appreciated.
Kind regards
Tony Barley
Tenerife
Canary Isles
Spain
Kind regards
Tony Barley
Tenerife
Canary Isles
Spain
