Stern light question
andyoxon
12 Dec 2005
Henley on Thames
A little advice sought if i may... If i'm fitting a transom mounted stern light on a rivergoing motorlaunch, which side should it go on, or should it go in the middle?
Thanks in advance!
Andy
I would place it as reasonably as possible on the centerline - ours is just off to starboard on the railing
Theoretically, in the middle, but it does not really matter. I would be inclined to choose the side on which you are more likely to be overtaken, if anything.
Ideally on centreline .... but if not possible - then it can be mounted anywhere that gives it the correct angle and field.
You could even if necessary mount on back end of wheelhouse overhang - as long as it is not masked by other objects.
The light does not "mark" exact aft centre of a boat ... it is to show that a boat is there !
