Hi there,
Can anyone give me some good ideas on wheel steering for a stern hung rudder?
I have a 31 ft steel yacht, which does not have a vertical transom. Somebody in a previous life has fitted wheel steering to her, which I like,but as the rudder is on the outside of the transom the steering cables have to run down through the pedestal, along the cockpit floor, up inside the transom, then out to the cockpit sides, then back to the quadrant on the front of the rudder. Its complicated and ineffective. I'm not really sure of a better way though, especially as it is not a rightangle from the cockpit floor up the inside of the transom. Otherwise I think I could easily make rack and pinion steering work.
The biggest problem is it makes the steering so heavy and complicated that my autohelm struggles, and my windvane does not have the power to turn the rudder. There is a lot of momentum in all that stuff! And my lovely cast bronze steering wheel is a heavy item, which i guess makes a big flywheel effect too.
I've been considering hydralic steering, but I'm reluctant as it is reputed to have no feel.
The other option seems to be go back to a tiller, but I really like the wheel!
Any suggestions from anyone??
Thanks very much,
Richard
Thanks very much,
Richard
