stern gland
ongolo
5 Aug 2003
I would use Lithium water resistant grease as recommended for boat trailers. If you have a steel stern tube, do not use any grease that contains graphite. Graphite, being carbon is very high on the galvanic scale and might cause corrosion.
ongolo
Thistle
2 Oct 2004
Here
Eh? Run that one past me again ...
boatmike
30 Jun 2002
Solent
In actual fact Graphite is No 92 on the Galvanic table. Just a bit less active than Gold and Silver. There is absolutely no reason to think Graphite grease would cause corrosion. Total rubbish!
geronimo
7 Nov 2003
And I am told that I do not need any grease, and that water inside will do the job
So are there some stern glands that need grease and some that do not
Ships_Cat
7 Sep 2004
Yes , there are some stern glands that require grease and some that do not. Those using mechanical seals typically rely on water lubrication and those using lip seals may rely on water, oil or grease. The seal on my own boat is normally just water lubricated (it uses lip seals).
John
