cindersailor
This is going to be a bit tricky to describe, but here goes. Having just installed the 1GM I have been tinkering with in the garage for the winter I am quite happy that it runs sweetly and is not squirting oil or water into the bilge. However, the inner part of the stern gland is running hot - almost too hot to touch after a long run, and this when the gland nut is only hand tight. I have loosened off the nut until a turn on the greaser allows grease to ouse past the threads, this lowers the temperature, but it still gets warm and I am concerned that the imperfect seal for the grease means that it is not being forced into the stern-tube and outer bearing. I should mention that the outer shaft bearing is not a cutless type, but rather a close fitting bronze one which I assume is supposed to be lubricated by the greaser. It appears to have the advantage that it does not allow any water through the stern tube.
I did not replace the original gland packing as it seemed to be looking good. Having done some research I can only find descriptions of stern glands that have the packing inside the gland body and this is compressed by a collar which fits inside the the body and is forced into the packing as the glad nut is tightened. However, the packing in my stern gland is contained in the cylindrical gland nut, and there is no room to fit any packing into the body of the gland which is a close fit around the shaft. If I completely unscrew the nut it is quite, although not completely, free to turn on the shaft.
The obvious solution seems to be to replace the packing and not to use so much so that I can screw the nut on further before it gets compressed. But I wanted to see if anyone is familiar with this design of stern gland and its peculiarities.
