Gludy
My new boat has the Aquadrive fitted.
They have also left a lubrication system for the stern gland and I am getting conflicting advice on this - its the rubber hose bit in the photo
Fisherman gave me these helpful remarks on another thread:-
"The rubber tube is jubilee clipped to the stern tube, and to the inboard gland which is therefore able to move. As your engines vibrate the shaft movement is accomodated by the rubber tube. Now you have gone over to Aquadrive, which accomodates movement in itself, the thrust bearing presumably holds the shaft firmly, so the flexi gland is redundant. I would have replaced it with a normal gland, screwed to the stern tube. As it is the movement in the inboard gland is no longer required, so the tube will not be flexing, and is unlikely to rupture. However, the sea is on the inside of that rubber tube, and you are floating on those jubilee clips. "
I asked a friend tonight and he said that its just the lubrication system for the bearings instead of the normal stern gland and that if the hose went yes it would leak but not rapidly.
I do not know if the way it has been done is a good thing or not and I would like to throw the issue open tothose who know a lot more than me about it - so what do you think of the system they have installed? How safe is it?
