Askival
I have purchased the Sterling pro digital regulator and remote control, I have soldered two wires to the alternator as stated in the installation guide, (this is to identify the field wire) one wire reads 14 volts the other wire reads 0 volts. I took the alternator to an auto spark and the alternator is working OK, he also stated that the voltage readings where what they should be 14 & 0. I cannot get reading 2-10 volts from either of the wires as per the Sterling installation guide. The only terminal on the alternator that gives a voltage of 7 volts is a spade terminal with a purple lead apparently for a tachometer, has anyone installed this regulator and had the same problems?. The alternator is a Valeo 35 amp and is new.
