vas
good morning,
have finally concluded home testing on a 304Ah 24V LiFePO4 battery bank with diyBMS controller and shunt, bought a BlueSea contactor and a Class-T fuse, so ready to move the lot onboard.
Now, charging sources are 3, two of them are sorted as they are a Victron MPPT solar charger and a Victron Multiplus both connected to a raspberry pi running VenusOS and charging states, levels and current is controlled by the rpi through the instructions it gets from the BMS. diyBMS talks Victronspeak and the main reason I opted for this BMS (as well as it doesn't resort to mosfets to disconnect power.
OK, sounds complicated but works fine.
Third source though is port engine alternator (60A) which is currently routed through a Sterling ProDigital Advanced Alternator Regulator, which needs to be also controlled as I tend to move from one place to another midday early afternoon and the battery will be full from the solar panels.
So after this intro, the simple Q is:
am I right in that passing through a 1A relay (onboard the BMS controller-will check with an ampclamp typical loads on this wire) the yellow cable (which is going to ignition or D+ or wherever it gets +24V in my case) I can safely turn Sterling output to the bank on and off at will without burning anything?
Or I need to consider something more advanced?
Am I right in that diodes cannot be destroyed in the alternator even at 2000rpm if the yellow cable is grounded and effectively the sterling output is killed and later on re-enabled?
cheers
V.
cheers
V.
