asj1
I wonder if anyone can help....
I have an older style Sterling Battery Monitor ( don't know how old as I bought it 2nd hand from this forum). It measures volts from two batteries and amps from a shunt in the cabling to/from the domestic battery. The unit indicates that it can do the same from 4 batteries, but I don't need this. It isn't the sort that measures what % of battery remains.
When I arrive at the boat after a week with all electrics switched off and turn the unit and batteries on it works perfectly well.
However once I either use the engine or shorepower it ceases to be of any use and when I switch it on to volts it starts at a number between 9 and 30 and counts up - I usually get bored by the time it reaches 100 or so and switch it off. Similairly the amps figure seems to be wrong as it is unaffected by how amny lights etc I have switched on.
Has anyone had a similiar problem?
Any ideas for causes/repair?
Could it be static causing this odd behaviour.
If I ditch it I will need to replace it with something to cover up the hole I will be left with. NASA seem to do something similiar for circa £100.
- Can anyone report how relaible they are.
- I belive the NASA unit is for one battery, but presumably a simple 3 way switch would enable it to do the volts from two banks.
Regards
Regards
