Cardo
Ok, I know I've asked a very similar question in the past, but I just need to get this sorted in my head.
I'll shortly be upgrading the alternator charging on le bateau, seeing as it is simply dire at the moment.
The two options I'm looking at are:
Sterling A2B:
http://www.marinesuperstore.com/item/99197766/sterling-alternator-to-battery-charger
and
Sterling Pro Digital:
http://www.marinesuperstore.com/item/07519/sterling-alternator-regulator-pro-digital
There's a £110 difference between them, so I would rather go for the cheaper one if it'll be ok with my setup.
Currently, we have 500Ah of sealed lead acids in the domestic bank, and a single regular lead acid (80Ah I think) starter battery. Alternator charging is from built-in alternator regulator, through a split diode. Charging isn't exactly fantastic.
The A2B charger looks easy enough to wire up. Bulk of charging goes to the domestic bank, and the starter battery receives a trickle charge to get it back up and keep it running. No probs there.
The Pro Digital, on the other hand, only has a single output, which you would then run through a diode to supply domestic and starter batteries. This is what has me confused. If you're putting a load of amps in to charge up the domestics, how is the starter battery not cooked?
There's probably some obvious reason for this not being an issue, but I sadly lack the knowledge and would like to ensure this practice is not a problem before I go for this option over the A2B charger.
Advice, as always, very much appreciated.
Sterling A2B:
and
