Stepping up 12v to 17v DC for laptop
martinb
27 Apr 2002
Solent
You could get a dc to dc converter, for the power you require it would probably be about £30
Martin
DeepAndy
11 Nov 2003
Deal, Kent
PC WOrld do a LAPTOP power invertor for £ 47 ......... I have one on my boat and have snipped off the cigarette end and wired it direct to battery. bloody good bit of kit
Andy
<hr width=100% size=1><A target="_blank" HREF=http://www.taurusdiving.co.uk>http://www.taurusdiving.co.uk</A>
martinb
27 Apr 2002
Solent
Yes that is an option, I was thinking of a dc to dc converter, rather than a dc to ac inverter. Like those <A target="_blank" HREF=http://rswww.com/cgi-bin/bv/browse/Campaign.jsp?BV_SessionID=@@@@1424941666.1075917607@@@@&BV_EngineID=cccfadckikjemiicfngcfkmdgkldfhn.0&cacheID=ukie&Name=new&stockNo=4528596> here </A> except I am sure that I have seen 12 to 17 volt somewhere.
Martin
jackho
22 Mar 2003
I have normally used a 12v DC to 230v AC Inverter to power my laptop onboard. (Presently £14.99 Maplins).
Recently as back up I purchased a DC to DC regulated Power adaptor INPUT DC 11-14volts OUTPUT Stepup 15 to 20 V , 70Watts max - Purchased on E-Bay direct from the US 14dollars inc. postage.
Hope this helps.
Jools_of_Top_Cat
16 Dec 2002
<A target="_blank" HREF=http://www.laptopshop.co.uk/laptop-notebook-car-cord/spscarcord.htm>http://www.laptopshop.co.uk/laptop-notebook-car-cord/spscarcord.htm</A>
Cheaper by far than manufacturers adapters.
Other way of course, is to buy two 6v lawnmower batteries and add them to your domestics, that way you can tap off 18v (ish) of clean DC. I think I am going to go this way so I can use my SSB to dowload weather fax. Using any small DC-DC adapter causes a fair amount of noise (elecrical).
<hr width=100% size=1>Julian
<A target="_blank" HREF=http://www.topcatsail.co.uk>Top Cat Homepage</A>
ex-Gladys
29 Aug 2003
Colchester, Essex
...That's how Dell do the business on you... Cheapish machine up front, proprietary components for which they charge an arm and a leg.
<hr width=100% size=1>Larry Botheras
Anderson 26 "Amber"
