use a motor as a generator. They are like the Mabucci motors that are used in radio controlled cars & hairdryers ( uses the element as a dropper to 12volts)
I wonder at the efficiency though. How do you intend to drive the generator? Wind or water? The design of propellor/impellor would surely be the limiting factor.
Those little motors are also used in Raytheon drive units for both tiller and wheel autopilots and seem remarkable willing to keep going even when their innerds appear horibly corroded by the oggin getting in.
Thanks everyone. The point of stepper motors is they have lots of poles so good output at low rpm and no gears. I've found one in an old printer so I'll experiment and publish something if it works out.
Hi
If you don't already know this internet site have alook the stock changes regularly. I've bought items from them over the web with no problems. www.greenweld.co.uk
if you are looking for robust stepper motors try any gaming machine supplier,these drive the reels on all friut machines and most suppliers throw out lots of these.Interested in how you can use these with any success to charge your batteries
