sarabande
I have been given a pair of dusty carbon fibre oars (sweep) from one of the dark blue rowing clubs. They are as yet uncollected, and I gather that the blade is not one of the latest Vortex/Concept types but more like a Macon.
I am churning some ideas around for
1. For yuloh-ing, will a shaped blade make use difficult, or does one compensate by a bit more effort on one push or pull ?
2. Thinking about the leverage of a rudder vs an oar: rudder 0.5msq at 0.3m from the bearings and the oar blade 0.1 msq at 3m from the rowlock. It looks as if the oar generates a lot more more steering effort, and right from th estern of the boat, not from the trailing edge of the skeg. What critical naval architect thinking am I missing ?
3. Modern self steerings use the water blade to provide power to the tiller. The blade being vertical and thin chord (high aspect ratio) looks very vulnerable ; does an oar system provide more power to the tiller, and is it less likely to be fragile ? Do I need to rethink an oar-based system for self steering, from the existing servo blade types ?
All contributions, suggestions, and developed ideas gratefully received.
- engineless propulsion using a rowlock on the stern ("yuloh")
- emergency steering in case one of those "whale killer" dolphins eats my rudder
- integrating the oar into a self steering system instead of using the servo blade connected to the tiller.
