Yeoman_24
I have stripped down my 1970’s steering pedestal on my Moody 30 to change the bearings. Pig of a job and I intend to do a PBO article...
... anyway, I want to fix the DMC top plate to the top of the pedestal bowl but with a gasket rather than sealant so I can get in every couple of years and check grease, etc, (points to bolt together are arrowed on the attached picture). I’ve had a bit of a look at the usual butyl tape, sikalex, etc options but like the ides of either;
Thoughts or experiences welcome please.
- A full width ‘gasket’, cut to shape from something like a 4mm closed cell foam sheet.
- Alternatively, my thought is for a (one side adhesive ) strip of closed foam draught excluder. About 6mm to 10mm wide and around 5mm high. The sticky will hold the strip perfectly in place on the pedestal stand while I screw down the top plate and compress the closed cell strip converting it into a sealing gasket.
