D
Deleted member 36384
I am trying to identify the my steering system and the bevel box. At first I thought it was an older Mamba system but clearly that is not the case as the old Mamba systems had a crown gear exposed below the binnacle and not a bevel box; at least according to the old Mamba manuals available on the web.
The problem I have is that steering is getting stiff. I suspect that it is this bevel box and that the lubrication has either been contaminated or dried out over time. There is no sign of leakage of lubrication.
I can lift the bevel box up, which is lifting the attached vertical shaft, quite easily, but it comes to a stop, not a firm clunk as if there was a positive stop (see second pictures). Below the pedestal is another bevel box that is firmly attached to a bracket under the cockpit deck, then steering then runs through a set of tie rods and universal joints, to larger bevel bow with tiller arm, which is connected to the rudders tiller arm with a tie rod.
There is no way I can see to access the shaft coupling bolts either below the pedestal bevel box, or at the bottom of the pedestal. Could the pedestal shaft be connected via a spline and I just need to apply more force to slip the spline out? Has anyone see such an arrangement before?
Can anyone identify the bevel box and describe what it is like i.e. oil filled, grease packed; there is no grease nipple. I assume by removing the four cap screws the back just pops off and every thing comes out that way, not sure at all how to take this apart.
The yacht was commissioned in 1974 and was built in 1973, Southhampton at Woolmastons(?) Yard. Can't remember the correct name. Previously Tarrona identified the Universal Joints from the tie rods as being ex Jaguar, perhaps the steering is assembled from automotive parts. Do folks know of a good outfit that could overhaul the bevel boxes.
Thanks,
BlowingOldBoots
Pedestal With Compass and Binnacle Removed With Bevel Box In Position
Bevel Box Lifted Up To Full Extent - Easy To Lift Up, Weight of Shaft Only
Binnacle Bevel Box Coupling To Shaft In Side Pedestal When Bevel Box Is Lifted
Wheel Shaft Entering Bevel Box
Lower Bevel Box with Lower Pedestal Shaft Coupling At Top Of Picture
Thanks,
BlowingOldBoots
