JerryHawkins
Currently have a Whitlock mamba-type steering system using bevel gearboxes and link rods and am considering switching to hydraulic.
Reason for this is I want to fit a "below decks" autopilot system and hydraulic makes this easy. Although the existing system can be back-driven, it would use up a large part of the ram's force to overcome it before the force required to turn the rudder in any given situation.
I am looking at 3 options:
1. Fit electric mechanical linear ram to existing rudder arm.
- backdrive load is a problem here plus fitting hassles
2. Replace one of the bevel boxes with a Whitlock mamba bevel box and mamba drive motor.
- most expensive, but simplest to fit
3. Replace with hydraulic steering system and use electric hydraulic pump.
- would lose "feel" through the steering plus hassle to change to this system.
Does anyone have any comments on the pros and cons of mechanical versus hydraulic or any ideas on which autopilot drive system would be best? I am currently leaning towards option 2.
The boat in question is a Colvic Watson 34'6" motor sailer displacing some 15tons.
Thanks all!
Jerry
Thanks all!
Jerry
