Talulah
The steering cable snapped on our boat over the weekend so for those interested I've detailed further info below.
Overview: Mounted onto the steering wheel shaft is a sprocket over the top of which passes a length of chain. The chain hangs vertically down either side of the sprocket. Attached to each end of the chain is a length of stainless steel rigging wire.
This wire drops down through the steering pedestal into the engine bay below. Each of the wires then pass around a pulley and enter the rear cabin through a sleeve where they exit under the rear berth and are attached to the rudder quadrant.
The cable snapped where it goes around the pulley in the engine bay.
I imagine this constant bending and straightening of the rigging wire causes it to weaken and eventually break.
If you have a similar system it's worth checking in the pulley areas for broken strands of rigging wire.
The situation becomes exagerated when people engage the autopilot without realising and try forcing the wheel.
In our case it is possible to steer using the autopilot as the ram is mounted directly onto the quadrant at the rudder stock. For those with an autopilot that has a belt that goes around the steering wheel hub it won't work for obvious reasons.
In addition steering was possible with the emergency tiller but as this is mounted on top of the rudder stock in the rear cabin visibility is minimal. You need a crew member to give directions.
I haven't yet fixed the cable but removal and refitting at the rudder stock end is straight forward. The binnacle end is slightly more difficult as you have to remove the compass and top section of the binnacle. The compass is wired in and will have to be disconnected. You need a socket set to reach the bolts for removing the top section of the binnacle.
Once removed (corrosion of the bolts permitting) it is still not easy to get to the sprocket. If the Steering pedestal has side opening for speakers, engine control or power cable it may help to get access through there. Having extracted the chain with the wire attached take to a local rigger/chandlery to renew. (Arthurs or Kiwi Rigging in Gosport.) Refitting is straightfoward. I anticipate 2 hours to fix plus whatever it takes to get the cable made up.
Should be done in time for next weekends BBQ.
