jonasbn
New Member
Hello!
I have no experience with steel hulls but from what I have read interior rust is the first thing to look out for when looking at steel boats. So I looked at this Swedish steel sailing boat from 1982. I know the hull is made by a professional company, but the interiors are often homemade.
I have three concerns about this boat.
1. The steel deck is covered with a teak deck, with some age on it so it's not perfect. I suspect some moisture finds it way to the steel deck. Which should be painted and treated, but I don't know that or the status of the steel deck treatment. Is that a terrible thing?
2. The bilge, where it "connects" to the keel have some rust. Is it normal corrosion or something really bad? See image.
3. The engine had a little bit of standing water under it.
How bad is this? Should I run away or is it all OK?
Thank you in advance
Jonas
Jonas
