Steel boat question
castaway
31 Dec 2001
Solent
What are those 'insulators' called...the ones we use for isolating, perhaps a stainless steel bolt, from the steel hull when bolting on a fitting or somesuch.
They look a bit like a top hat (and I've heard them called this).. with the hole for the bolt drilled through the middle.
Anyone know where I can get 'em?
Thanks Nick
raven
6 Sep 2004
Cheshire, England
Thanks Nick
Not sure about the name of the item you need but I would bet that these guys can help...
http://www.asap-supplies.com/ASAP/contact-us
I have a steel boat and have found them a very useful source of parts and equipment when others have been unable to supply.
KellysEye
23 Jul 2006
Emsworth Hants
We use paste that insulates stainless from steel. Can't remebember what it is called but every chandler stocks it. It works well. If the bolt is load bearing make sure of the structural integrity of what you use. On that note...
ean p mentions a plastic components company. I certainly wouldn't want to use plastic between steel and stainless.
ean_p
28 Dec 2001
Humber
So whys that then?........
KellysEye
23 Jul 2006
Emsworth Hants
>Was that Duralac per chance?
Yes that's it, thanks.
To me it doesn't make sense. Duralac does't affect integrity but anything plastic is going to be weaker than steel. Or am I missing something? I am always happy to learn something new.
ean_p
28 Dec 2001
Humber
me thinks you might be focusing too much on corrosion reduction issues as in between aluminium and stainless rather than addressing the OP's question.......tho' even in the former the use of plastic sheet, components and film is very commonly used, and purposely made to be so used in industry where applicable
castaway
31 Dec 2001
Solent
Duralac
Hi thanks for all the replies on this. Duralac is certainly very good for isolating differing materials and I have always used it on masts when riveting etc and things like using ss bolts to fix toe rails and so on.
On steel hulls the whole matter becomes more of an obsession, and a proper isolater / insulator is needed between metals.
Thanks for the suggestions to try RS Componants and Componants Direct...both have the items at pretty good prices and with good web sites..
All best Nick
