TQA
- Joined
- 20 Feb 2005
- Messages
- 6,815
- Location
- Carribbean currently Grenada
Also won't work with some transmissions, like hydraulics. At least the one I have.
Here's another trick. If you're stuck with two 12 V batteries that won't crank the engine but are not totally dead, connect them in series to get 24 Volts instead of 12 and it should do the trick. Reconnect back into parallel 12V configuration after it cranks. Be careful how you do this so you don't fry the alternator or other electrical stuff.
This will work and is often done BUT BE VERY VERY CAREFUL NOT TO APPLY 24 VOLTS TO OTHER 12 VOLT ITEMS. The magic smoke will escape.
