Starter motor shaft - plastic sleeve?
Tim Good
26 Feb 2010
Bristol
I’m just swapping out my starter motor on a Perkins 4.236.
I’ve removed the old one and just ahead of the drive pinion (gear) is a plastic sleeve surrounding the spring.
On my new (reconditioned) motor there is no plastic sleeve. I’m just curious what it is and if it is worth my removing it from the old one and placing it on the new?
Old and new pics below:
Hunterlees
2 Feb 2017
Northern Ireland
On your old starter- how can the pinion gear move horizontally along the bendix? it seems that the sleeve has been added to prevent that. In which case there is a difference between old and new starters.
Tim Good
26 Feb 2010
Bristol
Good question. They’re deffo the identical model so I just checked: It seems to just slide up and over the nut on the end.
William_H
28 Jul 2003
West Australia
If the plastic sleeve slides over the nut when the spring is compressed what would make it return to cover the spring? yes it might retain grease to a degree perhaps. I think I would leave it out. ol'will
penfold
25 Aug 2003
On the Clyde
It appears to be retained against the pinion by the spring; I imagine it is shaped like a plastic beaker with a large hole in the bottom. Quite a conscientious piece of detail design, I would retain it as it allows the helix to be greased with much reduced risk of the grease attracting dirt and causing subsequent binding, unshielded bendix gears should only be lubricated with graphite or other dry lubricant for this reason. On a boat the salt and damp atmosphere plus infrequent use mean surface rusting is a much greater hazard to reliable operation, grease offers much greater protection than graphite.
Refueler
13 Sep 2008
Far away from hooray henrys
There's an old seamans saying :
If it moves : Oil it
If it moves occasionally : Grease it
If it does not move : Paint it
Personally I'd leave that plastic off .... I have a Perkins 4-107 - with similar starter ... no plastic at all ...
