MedDreamer
I want to add a second battery to give back up for starting the engine.
I have a Battery switch that I have now checked is pre-wired (both positive terminals go to the existing battery so it currently works in both "1" and "2" on positions).
The present battery is rated at 110 Ah and I intend using this for "domestics" when at anchor.
If I do this I need a starter battery. Can anybody recommend a suitable battery and supplier.
Or would I be better keeping the existing battery for starting and buying the second one for "domestics" ?. If so can you recommend a good battery to perform this function.
Martyn
<hr width=100% size=1>Do you think a Fleming 55 would look out of place on Windermere?
Martyn
