tyce
With the isolator switch off something still drains my battery. If I leave it for a few days it will be flat, however if I disconnect the terminal and leave it for a week it holds it's charge perfectly so it is not a faulty battery.
The battery starts only the engine, the house battery's are separate but can be linked in an emergency to start the engine. The engine has a fancy little charger connected to the alternator.
So where do I start looking and what tests should I do and what if any is the likely culprit.
