ChiPete
Hi All,
I have a 2008 Beneteau 323. I want to fit the rigging and fittings to allow me to fly a spinnaker, as well as run the vang, clew outhaul and topping lift back to the cockpit. To do this, I need to fit a deck organiser, jammers and winch to the starboard side of the coach-roof.
Having looked into this, it seems to be nearly impossible to effect the installation of the deck gear. The reason is simple - Beneteau have decided to fit a solid headliner to the saloon and heads, something that wasn't present on earlier models. No headliner meant you could drill through the coach-roof and fit the load plates, washer and nuts inside, topping off the bolt with a plastic shroud.
Does anyone have a similiar boat/problem and can you give me any pointers as to how I can get around this?
I have spoken to Ancasta who are talking to Beneteau - initial findings don't look good. It appears Beneteau in their wisdom have fitted the headliner without thinking about how owners will fit deck gear to starboard after commissioning without destroying the interior..... /forums/images/graemlins/confused.gif
Any assistance would be appreciated.
Cheers,
Cheers,
