GDPR150987
Having recently read lots on here and other various websites about fuel bug contaminating fuel I was wondering what the collective thoughts were on plumbing in a seperate 20 ltr emergency (get me home) fuel tank.
My current set up (motor boat so no sails) is a single engine and tank, fuel supply filtered by Racor turbine 500 unit and engine mounted factory filter. I have a spare set of engine fuel filters and Racor filters should the worse happen. Having changed the engine filter several times I would not look forward to doing it under stressful conditions at sea given its hard to reach location. The Racor filter is easy to do though.
I have a spare Barrus 20 ltr tank knocking around at home (internals cleaned out) and so my thinking is that I could fill this with fresh fuel, treat with Marine 16, plumb into main fuel tank outlet and isolate it with a ball valve. Then if I ever found myself in a situation of either contam fuel or running out of fuel I could just deisolate the standby tank and use it to get me somewhere safe. An added advantage is I can easily visually inspect the tank and fuel in the standby tank where as I have no way of checking the state of the main tank.
My only concern (not a big issue though) is how long it would last as the engine will still return the unused fuel back to the main tank as the new standby tank is a feed supply only, no return.
What do you think - worthwhile or not?
Cheers
Cheers
