Oscarpop
Our 6hp outboard has run perfectly for ages.
Recently it either starts and runs for about 30 seconds and then dies, or when it does run cuts out after a couple of minutes. The engine sounds laboured and then cuts out.
The fuel is good and I have used both the internal tank and external, both e same.
So tomorrow I will check and possibly change the spark plug , clean the injectors of the carb and check the fuel lines and filters.
Any suggestions as where to start? Which is the more likely culprit?
Cheers
Cheers
