mick
I have always used galvanised thimbles to join rope to chain, via a galvanised (12mm) shackle. If I use a stainless thimble, I know this will cause the shackle to rust, but will this corrosion be bad enough to significantly weaken the shackle, or will it merely be superficial? Because modern, so-called galvanised shackles corrode quickly anyway, I replace the shackles every year.
