jwilson
I am long and sadly familiar with stainless bolts/studs/shafts getting stuck through corrosion when fitted into aluminium fittings on items such as my windlass, small outboards etc. I am about to do the Mk III modification to my quite thin-walled and slightly flexible Jeanneau-fitted black polyethylene diesel tank, and intend to have alloy plates inside and out of the top surface, the inner ones having alloy rivnuts set into them into which S/S machine screws will compress a cork nitrile gasket, with some Hylomar Blue to seal the threads.
Will SS/alloy interfaces still corrode when liberally and regularly sloshed with diesel? I am hoping not, as part of the Mk III modification is to have a decent and reasonably easily openable access panel for internal cleaning.
Before anyone suggests just getting a new tank made, the shape is a wildly complex plastic moulding to fit in an under-berth space. Any 'made up' tank would lose a lot of volume, and be quite difficult to fit securely.
