AJAWATER
New Member
I have recently taken on the restoration of a 1936 Elkins Yawl. The boat is generally sound but has suffered damage to the keel after several years in tidal jetty.
I have noticed that 4 of the aft keel bolts, extending from the inside down to the underside of the keel are Stainless Steel. (approx 500mm x 15mm dia.) Is this a potential galvanic corrosion problem?
What, if anything should be done?
Also some stainless steel stiffening has been fitted in the bilge between a floor and the centreboard casing. Is this a problem?
Many Thanks.
Many Thanks.
