Boo2
Hi,
I've just had a stackpack made and there is a problem with it which I would like the forums advice on before talking to the vendor. Sunrunner has a mainsail with a bolt rope but this does not extend all the way to the clew, instead it stops about 3/4 meter or so forward of the aft end of the boom and the sail is relieved to allow the reefing lines to be tied to the boom.
The stackpack I've had made has a mesh piece at the bottom that goes in the boom slot and is trapped by the bolt rope in the normal fashion. This leads to the issue that aft, where the sail has no bolt rope, the stackpack is not retained to the boom in any way. There are two obvious solutions, one is to sew a piece of bolt rope into the aft region of the stackpack itself, and the other is to sew in straps that tie the stackpack to the boom.
I'm completely confident the vendor will fix the problem but I just wanted opinions as to which of the above fixes would be preferable in practice, or is there a better way altogether ?
Thanks,
Boo2
Thanks,
Boo2
