Gustywinds
After 5 weeks of boat ownership and 2 weeks actually using her, we’ve got our first fault.
The ST6002 Autopilot display LCD goes very faint after 40-45 minutes and then shuts off a few more minutes. As far as I can tell, the unit is still working as it will hold a course and change 1 deg when the +1 or -1 is pressed ( we are in a canal so using +/- 10 is a bit risky.
Switching off and on again does nothing, switching off for ~ 15 mins and then on restores normality for a further 40 mins
Backlight is working, contrast is already at max (15) when it is working.
I assume the LCD or its driver is overheating and is probably heading for complete failure?
It’s not really an issue in the short term as we are going to be on canals for quite some time but I’d like to get a fix ready for some point in the future. There are a couple of secondhand units on EBay, one in Denmark, one in Ireland but I’m thinking this might be good money after bad and I might be better going for something newer.
Any suggestions? It’s being fed from a new Garmin 1223 installed 3 weeks ago and the guy who installed it tried to upsell l to a new Garmin autopilot system but that was going to be around 3000 Euro. Presumably I can just replace the Autopilot display rather than everything if I stick with Raymarine or are there compatibility issues with old/new stuff?
