ST50 round seatalk pinout?
stav
7 Aug 2002
Jersey
Hi,
Trying to see if an old st50 wind system works but for starters does anybody know the power connections for the old round 3pin seatalk connectors. I am sure I have found this on the tinternet but no luck tonight...........
Stav only wanted to know the pin assignments for a wind instrument 3-pin plug.
I think I've seen it somewhere too but can't find where
Does the connector have tiny numbers moulded on it by the connections? If so, I think 2 is 12v positive, and 3 is 12v negative.
As it happens I have one on the bench here, and I've just buzzed it out for you.
Describing the conductors based on your picture of the female side, the left-hand pin is negative, the right-hand one is positive, and the bottom one is seatalk data.
Jeepers - a 41 page technical manual for a hydraulic autopilot! Stav only wanted to know the pin assignments for a wind instrument 3-pin plug.
Well may I apologise for attempting to help someone. I misread what instrument he was using.
Thanks for the replies, any offer of help is appreciated.
Thanks pvb, sure I have seen numbers before but not on this connector.
thanks prv, I thought I had a spare floating around but didn't, effort appreciated. I have attached the photo again marked with +ve and -ve just to make sure.............
thanks.
