KAL
Did the bearing change on my ST50+ wind transducer and remounted. Was working beautifully, but the cockpit display now shows 0.0 kn and needle does not move when wind changes. Have swapped the transducer but exactly the same symptoms.
The wire to the socket at the masthead is quite tight and I feel it’s likely that the power feed (or one of the other 4 wires may have come adrift, so need to get back up there to repair.
Has anyone else done this aloft, and if so, can you tell me if the connections inside the DIN socket are soldered or are they push/screw fit. I know they are going to be tiny and awkward to work on up there and am not looking forward to the job, but any pointers would be welcome. I do have a gas soldering iron, but soldering and I are not the best of buddies, even on a workbench.
...or do I just cave in and get a pro to go up and do the job?
