Hi
I'm in process of buying my first yacht (secondhand) and considering installation of a SSB radio. I want one that I can use on amateur bands and occasionally on marine bands if I need to.
1. I understand that as a UK registered yacht, I cannot install an Amateur transceiver modified to cover the marine bands for reasons of type approval. Is this correct?
2. I would need to modify the backstay to add insulators. Is the best approach to assemble a new insulated backstay and then replace the existing one.
3. How easy is it to reprogram an Icom 802 for amateur bands transmit?
4. What's the best place to get an RF earth for the ATU (I expect that the radio does not need an RF earth). I envisage two options - using the keel or installing a seperate plate. I'm uncertain that the keel is earthed anyway and would appreciate comments re the effect of such installation on corrosion.
John
John
