PaulJ
I am installing an SSB in my steel boat. The installation instructions state that the case of the transceiver should be grounded…… but to what? Since it is a steel boat I have taken great care to isolate the electrical system from the hull and whilst I understand that the ATU has to be grounded to the hull to provide a counterpoise, I am a bit nervous about grounding the transceiver because as far as I can see, this will connect the negative side of the whole electrical system to the hull.
Would it be sufficient to ground the transceiver to the negative side of the boat’s electrical system which in turn is grounded to the engine but insulated from the hull ? On the other hand, if I have to ground the ATU anyway, does it make any difference if I also ground the transceiver ?
Would a practical solution be to put switches in the grounding straps and only make those connections when the SSB is in use so as not to provide a permanent route for any electrical “leaks”…..?
<hr width=100% size=1>I used to have an open mind but my brains kept falling out.....
