SSB 7m Whip Antenna - Mounting?
little_roundtop
21 May 2011
Greece & UK
tntatsea.wordpress.com
I have a friend (no, really I do :)) who's fitting SSB to his steel yacht (a Bruce Roberts 53 design). He has a Glomex RA700 7m whip antenna which he has mounted close to the mizzen shrouds. To ensure it is completely supported he has tied it to the shrouds at regular intervals and even tied the tip to the mizzen spreaders. The antenna thus lies completely alongside the shroud.
I have suggested that this close prxomity to the (grounded) shroud may reduce the effective range of his SSB. I have suggested he moves the antenna to the stern away from the masts and standing rigging. He is concerned that the antenna may then be at risk if it is only supported only at it's base and at the top of his pushpit (about 1m up from the base). The instruction sheet says it should be supported 1.8m from the base but makes no other mention of additional supports.
What does the panel think? Is he making a grave error running the antenna so close to the shroud? And would the antenna be secure mounted at the stern with an additional support around 1m up from the base. I see this setup on many yachts. He's planning a 3-year voyage from the Med to Australia.
Thanks for the advice!
Tony C.
