mrplastic
Motoring out of the marina today I could hear a squeaking noise which I traced to the Volvo Shaft seal. This was burped and greased a couple of weeks ago and up tiill now it has been fine. (Prior to that I had motored the boat for several hours after a relaunch being unaware of the need to burp). I moved it a little bit further down the shaft as the shaft was showing slight signs of wear The squeaking comes and goes but the seal is not leaking, the seacock feeding the cutlass bearing is open and working. Do I need to be concerned? Must I replace it as a matter if urgency? What if anything can I do about it?
As always, my thanks for your sensible replies!
