statgar
I have a problem with a Tecma WC in the master cabin which is overfilling I've tried adjusting the timer on the controller but its on minimum now. I need to get to the valve in the supply pipe (fresh water) in the hopes that I can reduce the pressure. Does anyone out there know anything about the pipe layout on these boats before I start ripping the boat apart? I've traced it so far to the companion way stairs but then it disappears under the head of the master bed, I think it should probably go to a manifold somewhere but darned if I can find it. Also I can't find the holding tank/sea outlet change over valve I have the one for the day heads but not the master.
Any help greatly appreciated as always, there just doesn't seem to be a 'go to' contact out there for information on this boat, Fairline don't want to know as is the case with dealers BW.
