libellule
Active Member
As previously posted, I am doing up a Windy 525 I bought here in France. Have taken on board your replies to my previous question about the need for spreaders and have now sailed her in very light winds with no spreaders and was a little alarmed about the movement at the mast head. The mast is 7.5 metres high and the shrouds are fitted at 3 metres from the base. I have sourced a spreader fitting for my mast, very old, make unknown but basiclly an oval shape 7 x 5 cms. I have sourced spreaders that I can adjust from 350mm to 450mm. My question is..........where is the best height from the base of the mast to fit the spreaders? is there a formula? or is it just a matter of trial and error. The Windy website says they should be 40cms long and at an angle of 120 degrees. The fitting I have sourced allows for the angle to be adjusted. Any help appreciated.
