spraying with perfection paint
boaties
New Member
27 May 2022
just curious if anyone have sprayed with perfection paint by international If so has anyone attempted to spray the undercoat and then top coat on in the same day I do know it says to apply undercoat wait for 24hours before sanding depending on the temp for drying time but if pushed to paint in a time limit could you spray u undercoat wait till touch dry and start top coating
TDS ( technical data sheets) are your friend here and with all coatings,
follow all instructions to the letter, preparation, and cleanliness is key with all painting.
Most importantly is the dew point ( the time when condensation gathers on surfaces )
It is very hard to know when its there or not as it does not always show as wet surface, get this wrong and the paint will not adhere to the surface and fail later on.
if you have a well ventilated area that is warm a dry this will or should be fine.
The data sheet does not state wet on wet coating so it is not recommended and with very slow drying paints you run the risk of solvent pop where the solvent has not flashed off the paint and get trapped only to pop as blisters later.
If you look at this data sheet it gives you all the info you will need from spray equipment set up, thinning, and application to drying times.
Perfection_Pro_eng_A4_20190131.pdf (international-yachtpaint.com)
Also this is a 2 pack paint so air fed breathing equipment should be used this is dangerous stuff.
So look up the HSDS ( health and safety data sheet) as well.
